Question for those who swapped in 6 speeds??
Old Jan 9, 2002 | 04:41 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm thinking of buying the 6 spd that's made for thirdgens. My question is, with 6 spd trannies you have to cut the hole in the tranny tunnel bigger, but what boot do you use on the tranny tunnel to make up for the larger hole that you've cut? Do you just need a 4th gen one or what? Thanks.
Old Jan 9, 2002 | 04:53 PM
SteveSpohn's Avatar
If you're saying you are going to go with the aftermarket T-56 that adapts to the T-5 bellhousing like the one we sell, the shifter on that unit lines up directly with the T-5 hole in the floor there is no need to cut a bigger hole like you do with a 93-97 T-56.
Steve
Old Jan 10, 2002 | 02:57 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Steve
Great!! Thanks for enlightening me, I was under the impression this one needed you to cut the floor too, you just made me a lot happier once this time comes around.
My only other question is I have a '90 Camaro, which you know uses and electric speedo. Can that aftermarket T-56 you sell work with the electric speedo without any changes? Thanks again, that's a great company you have.
Old Jan 11, 2002 | 10:22 AM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
ttt, steve another question, thanks again
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
