Plastic slave cylinder broke 10 mins after install
Old Jun 26, 2019 | 08:55 AM
mikasa337's Avatar
I had a bad plastic one in it and assumed I could replace it with another plastic one and a few minutes after bleeding it and letting it sit, I push in the clutch and it snaps the plastic. DId I do something wrong are the plastic slaves really that bad?
I ordered two aluminum ones to see if that really was the issue. So if anyone is wondering on getting aluminum, ill update this.
Update, aluminum slave works great, haven't had any issues. Plastic was crap.
Last edited by mikasa337; Jun 29, 2019 at 01:12 PM. Reason: Updating after install and driving
Old Jun 26, 2019 | 10:20 AM
GeneralDisorder's Avatar
Re: Plastic slave cylinder broke 10 mins after install
Probably depends on how stiff the clutch is. Worn clutches tend to have the pressure plate diaphragm "sprung" outward and that seems to increase the pedal effort. Also if nothing is greased (fork pivot, trans quill, etc) more effort will be required. Too much force being applied through the slave could break it if it's not strong enough. That's probably why the aluminium slave cylinders exist I'm guessing - for heavy duty applications.
GD
Old Jun 26, 2019 | 10:24 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Good luck after I installed my spec clutch both my master and slave plastic versions started leaking. Replaced both with aluminum versions from advance auto a few years ago no issues worth the $75 for the pair
c4mo
Mar 1, 2014 11:14 AM
Looksthakill
Alternative Port EFI Intakes
Oct 9, 2011 11:01 PM
lumpylee
Sep 6, 2003 06:17 PM
99Hawk120
Jan 17, 2002 01:24 PM
Zepher
Nov 22, 2000 04:33 AM
