my 90 I roc z only has Drive,no reverse or neutral
Old Jun 24, 2019 | 09:09 AM
carstamper's Avatar
When I got off the Freeway, I tried to put the car in reverse, the shifter goes to reverse but the car stays in drive,I shut the car off & put the shifter in Park . When I start it in park ,the car starts & is in drive & goes forward immediately. There is no neutral either, The car only moves forward. Is it linkage ? I pulled the shifter housing off in the car ,it looks ok. I can only move forward.
Old Jun 25, 2019 | 11:00 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Re: my 90 I roc z only has Drive,no reverse or neutral
I would say shifter cable either broke or came unhooked at the tranny.
Old Jun 26, 2019 | 09:10 PM
Drew's Avatar
It's sure worth making sure that when you're moving the shifter that the lever on the trans is moving into the corresponding gear. That said, if park feels like it's trying to drive forward and it's only stopped by the parking pawl, and R is drive, and N is drive, and OD/D/2/1 are all drive, you've probably done one too many neutral drops. Sometimes.... Some times, you can 'rock' the car while modulating the throttle and brakes, and break the transmission loose again... Some times after getting the trans broken loose again, it'll mostly return to normal, until the next time you do a neutral drop, or otherwise beat the **** out of the trans. But really, something in the trans is likely fragged, and the real fix is to have it rebuilt.
Old Jun 27, 2019 | 02:49 PM
carstamper's Avatar
I found the answer ,I took it to a Garage and the Trans shifter bracket was detached, 2 missing bolts were installed at the transmission, and that fixed the problem. John
RAV3N
Jul 21, 2005 04:05 PM
90Iroc-Zee
Theoretical and Street Racing
Jun 23, 2002 09:57 PM
ThirdgenCam
Apr 18, 2002 08:56 PM
