z-28,I roc, rs, z-28 i roc???
they are all similar except for the RS. I think the Z28 and IROCS look best because of the louvered hood/blistered hood. you could order both with the 350tpi 4 speed and 305tpi 5speed. those are the two best stock motors beside turbo trans ams and firehawks, if you would call that stock
quick down and dirty camaro lesson
82-87 they made Z-28's
85-87 they had both Z-28s and IROC-Zs the IROCs were performance add on (suspention and stuff like that)
88-90 they droped the z-28 and only had IROCs
(and V6 camaros too)
91-92 they went back to z-28s
89-92 they made the RS (V6 and V8)
the RS had a 305 tbi engine
the z-28s and IROCs had 305s and 350s, TPI
the best would be the later IROCs with the L98 engine (350ci {the same that was in the vette at the time})
that is a quick and dirty
later
biker
later
biker
Car: 99 Formula
Axle/Gears: 342
You could get a 91-92 350TPI, also a quick correction about the run down list, they did make TBI IROCs, what were they thinking..
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Re: z-28,I roc, rs, z-28 i roc???
Originally posted by ThirdgenCam
Wich has bigger stock motor? and looks best???
In looks, IMO the IROC-Z looks alot better than the 91-92's, and I think they might handle slightly better than them too. But the later cars are probably slightly faster, maybe.
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i shoulda said that you couldnt get the 350 TPI in the 87 Z28
THAT had to be an IROC to get a 350 TPI
:lala: :lala: :lala:
louishenry
Aug 28, 2015 09:41 AM
