Stealth Ram TV Cable Length ?
Old Jul 2, 2019 | 09:36 AM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Using both my stock TPI TV cable (43.75'') and bracket on a stealth ram, i have to really pull the square tab into the bracket to get it to reach and snap in. There is no slack at all then left in the outer sheath. If all adjusts fine with the inner cable, is this an issue or is it possible the stealth ram mounting holes for the bracket are ever so slightly to the front more? It also could just be the way the cable is routed from the trans, but I've been trying to snake it around different ways and have yet to do anything to extend it 1/2'' or so. Appreciate any feedback.
rottweiler68
Jul 2, 2019 08:54 AM
Fronzizzle
Alternative Port EFI Intakes
17
Jan 9, 2012 09:01 PM
jdaniel
May 9, 2003 08:06 PM
