Major transmission issues after servicing (automatic)
Old Jul 6, 2019 | 11:27 PM
3rdhill's Avatar
I have recently purchased a 1983 Camaro with the 305 and 4 speed transmission. I have since put a number of hours into working on getting it road worthy. The car ran and drove well before I serviced the transmission. Since I have Changed the fluid I instantly noticed some major issues from the transmission. Including a whining Torque converter, Slipping gears and a burning smell. I am afraid that o ring in the filter was not seated correctly or it is not getting enough fluid. Are these real concerns? What should I do?
Old Jul 7, 2019 | 12:19 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Major transmission issues after servicing (automatic)
Drop the pan and check the filter, sounds like it wasn't installed properly and came loose. Did the old filter have the seal on it? Maybe it's double sealed and caused the filter to fall off.
Old Jul 13, 2019 | 06:56 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Was the fluid dirty when it came out? And did you use mercon 3?
koolz
Dec 28, 2015 03:09 PM
Matt Bane
Dec 19, 2009 10:11 AM
viking28
Mar 31, 2002 04:19 PM
92GTA
May 1, 2001 02:52 PM
P J Moran
Feb 4, 2001 05:05 PM
