T5 & 350ci ----> starter question
Old Oct 10, 2019 | 03:47 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Going to be installing a T5 onto a 350 soon and wanted to get the groups input as to the starter. Car is a 91 & - working from memory here - IIRC I've got 3 options:
1: Use the larger automatic starter and modify ( remove ) the starter notch on the bell-housing ?
2: Use the smaller 'manual' 305 starter ?
3: Use an LT1 starter ?
Planned to use a stock T5 flywheel for 1-piece RMS ( PN = 14088671). Any input or suggestions ?? IMO using an LT1 starter seems to be the best option here,... just not sure if it will match-up to the the flywheel properly. THANX in advance !
Old Oct 10, 2019 | 05:25 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: T5 & 350ci ----> starter question
All I know is the LT-1 starter is expensive, like close to $200 if you don't have a core to exchange. I'll get one someday, but for now, gonna try to use the stock starter from an '84...
Old Oct 11, 2019 | 01:12 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
IIRC the ~'96 corvette starter is an option too. I have one, but not had a chance to install it yet.
Old Oct 11, 2019 | 01:26 PM
John in RI's Avatar
I've got a used 95Z LT1 starter and was hoping that one would work. New ones are pretty expensive,........ but so is a bell-housing. I really don't like the idea of cutting off the starter notch from the bell-housing; I know it's an option ----> but don't really like that option.
I don't KNOW if the 95Z LT1 starter will "mesh" with the flywheel I'm using,
I have no experience with the smaller "manual" thirdgen starter when bolted to a 1pc RMS 350.
Old Oct 11, 2019 | 08:06 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
This is the one I used with my T56 swap it has a 153 tooth flywheel also. Starter seems to be holding up. quite and is pretty small and light.
best of all it's about $62 shipped
https://www.amazon.com/gp/product/B008Y3NZ0W/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B008Y3NZ0W/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Old Oct 12, 2019 | 11:05 AM
John in RI's Avatar
NICE !
soarestransam
Sep 9, 2012 12:31 AM
online170
Jul 8, 2009 09:23 PM
jayk2k3
Sep 3, 2006 05:43 PM
