T56 Transmission feels loose?
Old Nov 1, 2019 | 06:08 AM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
I have a T56 transmission in my hot rod. Bought ut used. Mileage unknown.
It work well. No problems. No bad sounds or antything.
But the gear stick feels loose. At lest compared to the manual transmission on my modern daily driver.
Not easy to shift fast, because of the looseness.
Is this kind of normal, or do I have a transmission that soon will have to be rebuilt?
I use the recommended oil.
Old Nov 1, 2019 | 12:25 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: T56 Transmission feels loose?
Probably the plastic cup the end of the shifter rod goes into on the shift rail #95 in the manual is worn. You can get brass ones from the gearbox
Old Nov 1, 2019 | 02:29 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I like the proper epoxy and a new stock bushing.
Before doing that, pull the console boot and see id the stick / upper shifter parts are loose.
Old Nov 1, 2019 | 03:18 PM
Hotrodder's Avatar
Engine: 350 CSB
Thanks for your advices.
Is this plastic cup /bushing fairly easy to shift?
Old Nov 5, 2019 | 07:33 PM
jmd's Avatar
jmd
On the T56, the replacement plastic cup must be epoxied in place.
The plastic will usually be quieter than the bronze. There won't be a noticeable ease of shifting for one compared to the other.
firechicken1992
May 6, 2016 10:52 AM
BigBoi4Lyph
Dec 18, 2006 09:36 PM
88 Camaro SC
Apr 25, 2002 12:32 PM
