700r4 no overdrive
Old Dec 18, 2019 | 09:45 AM
1badmaro's Avatar
Car: 86 camaro
Engine: 355
Axle/Gears: moser 12 bolt 4.30 gear
700r4 no overdrive
1992 700r4 with new TCI reverse manual Valve body TCI 10" non lockup 3800 converter. Fresh rebuild with red eagle clutches and kolene steel's. Boeg Warner 3/4 clutch maxpack . 5 pinion gear sets. Sonnax super 4th servo. Sonnax pinless accumulator piston kit. Sonnax 2nd gear super hold servo. New sonnax sunshell. Will not shift in 4th gear. Verify shifter is adjusted correctly. When shift it into 4th gear trans just stays in 3rd gear.
Old Dec 18, 2019 | 11:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: 700r4 no overdrive
Did it go into OD before the rebuild?
Who did the rebuild?
Old Dec 19, 2019 | 10:45 AM
1badmaro's Avatar
Car: 86 camaro
Engine: 355
Yes before rebuild overdrive worked. a friend of mine did the rebuild
Old Dec 20, 2019 | 01:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm no tranny guru by any stretch, but I think I'd start by checking the line pressures in each gear first. A manual will have the specs. Regardless, my guess is at a minimum you'll need to drop the valve body, I assume there are check ***** like in the TH350/400? Possibly incorrect spot/missing?
Old Dec 20, 2019 | 01:13 PM
1badmaro's Avatar
Car: 86 camaro
Engine: 355
Only check ***** in the TCI RMVB are in the auxiliary valve body and it's there
Old Feb 28, 2020 | 05:15 AM
1badmaro's Avatar
Car: 86 camaro
Engine: 355
Fixed!! swaped out the sonnax super hold servo with a new corvette servo and OD works perfect. not sure whats wrong with the sonnax yet.
Joe McConnell
Nov 15, 2019 11:58 AM
BigChevyFTW
Oct 22, 2015 04:35 PM
richw40
Mar 19, 2014 09:56 PM
alxtre99
Sep 13, 2006 05:40 PM
