my700r4 wont shift out of first!!
Old Sep 5, 2006 | 06:45 PM
alxtre99's Avatar
Car: 91' Camaro, 71' MERCEDES
Engine: Camaro 3.1L
it'll engage into every gear fine, no problem there. but when i put it into OD there's a hard jolt when it engages. first gear takes off fine but thats the only gear i get. it will not shift out of first no matter what i do, it kinda feels like it's slipping, any ideas?
Old Sep 6, 2006 | 07:52 PM
Camaroreaper's Avatar
Torque Convertor or Rebuild
I had a similiar problem with my 1987 IROC i eventually went for a new tranny all together. You should rebuild it. Easy as Pie....Pay someone $500 to do it. Either case this is going to cost you $500 around, Im happy that i have a 4l60E with trouble codes etc. 700r4 after a rebuild you should expect another 50,000 miles easily. I say get the tranny rebuilt for $500-600
Old Sep 6, 2006 | 08:11 PM
84matrat's Avatar
Car: 1984 Camaro
Engine: 305...soon to be 383
Transmission: 700R-4
check that trans fluid. it seems like your problem might be more complex but i had a similar problem with mine not going into 4th gear.. check the fluid while running and perhaps that'll be a quick fix -vs- a trans rebuild. its always worth a shot.
Old Sep 7, 2006 | 06:34 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Pop the governor out. Inspect the gear and make sure the valve is working smoothly. If you are lucky, it is sticky or the gear is chewed up. It would be lucky because it would be a $10 fix.
Old Sep 7, 2006 | 09:33 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i second this. been there done that.
Old Sep 7, 2006 | 11:55 PM
vap3r's Avatar
i third that, been there done that
Old Sep 11, 2006 | 07:54 PM
alxtre99's Avatar
Engine: Camaro 3.1L
i'll get on that governor thing, where is it located and is it difficult to remove?
Old Sep 11, 2006 | 08:17 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
your tv cable aint adjusted rite pull out a lil slack
Old Sep 11, 2006 | 09:50 PM
alxtre99's Avatar
Engine: Camaro 3.1L
so i drove the car to the back of my work and threw it on a lift, then i popped the cap off that covers the governor and had a look, it turns out the governor gear was completly broken off of the governor, lol...... the tranny tech didn't even guess that, that was the problem, so i'll fix that tomorrow and see how she drives, i'll let you guys know, thanks
Old Sep 13, 2006 | 11:48 AM
alxtre99's Avatar
Engine: Camaro 3.1L
so it turned out that the gear on the end of my governor was chipped, stripped, broken, melted...... so i had it replaced, (not to mention the broken part was actually stuck in the tranny), and now it drives sooooooooooooo smooth and it only ran me about $30!! thank you guys so much i really needed this......... once again
Old Sep 13, 2006 | 01:16 PM
Car: 1988 IROC-Z
great to hear.
Old Sep 13, 2006 | 05:40 PM
vap3r's Avatar
lol when that happened to me i took my governor out and drove a different car to a local auto trans shop and they drilled a new gear in for 10 bucks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
