do i have a 10 bolt or 9 bolt?what series carrier??
Old Jan 13, 2002 | 12:50 PM
redtail2426's Avatar
I have a 88 transam 305 tpi auto i know i have 2:73 gear ratio with posi but do i have a 10 bolt or a 9 bolt and what series carrier 2 or 3 i want to order 3:73's for it and dont know what i need thanks for the help.
Old Jan 13, 2002 | 01:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well its difficult to say. All of the TPI TA's Ive seen have 9 bolt posi rear ends. Your going to have to crawl under there and count the bolts on the differential cover. If It is a 10 bolt and 2:73 gears its a 2 series carrier. #1 is the order no. you will use for ordering gears.
SSC
Old Jan 14, 2002 | 10:52 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What is exactly a 9 bolt rear-end? I know what a 7.5 , 10 bolt rear end is. What is the difference between a 10 bolt and a 9 bolt?
Old Jan 15, 2002 | 08:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The number of bolts. The rear end is completely different, and as the name implies, the cover is held on with 9 bolts instead of 10 like on the 10 bolt. The 9 bolt is a lot stronger than the 10 bolt, and has the advantage of being able to shim the cones when the posi starts to slip, but parts are hard to find and expensive.
Old Jan 15, 2002 | 12:37 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Hard to find. NO - I have gear ratios up to 4.10 available. Also new series 3 posi carriers and other stuff. All the info is on my page at www.koolmeister.com
Expensive. That's relative. To a weak 10 bolt, yes. To a complete 9 inch or 12 bolt, no.
Miles
Old Jan 17, 2002 | 11:31 PM
MR KEITH's Avatar
THE 88 AND 89 B/WS ONLY HAD 2.77,3.27,AND A 3.45 GEARS.IF YOU FIND THE AXL CODE SEE IF THE FIRST THREE CARICTORS ARE, GH3 "2.77 B/W 9 BOLT POSI", 6HT "2.73 10 BOLT POSI",OR 6HP "2.73 10 BOLT STD".IF ITS SOMETHING DIFFERENT POST IT AND I CAN TELL YOU WHAT IT IS.HOPE I COULD HELP,LATER
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
