Sonnax smart shell torrington bearing
Old May 7, 2020 | 09:07 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
I’m having trouble figuring out which way the Torrington bearing goes on the shell the picture with the instructions is hard to understand
Old May 7, 2020 | 11:04 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
Re: Sonnax smart shell torrington bearing
It wants the opening to face away from the shell. I just rebuilt a Dodge 42re for my truck, you can typically lay the torrington onto the parts it mates against and figure out if it's going to spin freely that way or not. Hope that helps.
Old May 8, 2020 | 10:59 AM
Looks pretty straightforward. Very good diagram.
You lay the outer race (flat piece that fits fairly tightly to the shaft-like thing it sits on) on the shell, then lay the cage (slightly narrower piece with large inner dia with the rollers in it) on top of and inside of that.
chevy2424
Dec 28, 2014 04:26 PM
87irocftw
Mar 23, 2012 03:53 PM
drex
Apr 26, 2006 11:18 AM
