Going to automatic
Old May 14, 2020 | 07:49 PM
Sling Meister's Avatar
Going to automatic
Am going automatic with a 700r4 in a 83 camaro. Is all I need is the transmission, torque converter and automatic shifter. What are the difference between these two shifters
https://www.ebay.com/i/352883519528?...26pg%3D2386202
https://www.ebay.com/i/352606044462?...CABEgJiIvD_BwE
Old May 14, 2020 | 08:27 PM
Re: Going to automatic
Neither is what you want.
You need a 700 shifter from 83-92 Camaro. Along with the console top and shifter boot. And a WHOLE LONG LIST of other stuff. A flex plate for example; various wiring; a TV cable, and the brackets & linkage pieces to make it work; a different PROM, so the converter clutch will work; a torque arm bracket; maybe a few other items, depending on what you're taking out.
Old May 15, 2020 | 12:38 PM
ken23434's Avatar
Car: 1986 Z-28
Engine: LB9
I just pulled the 700R4 out of my 86 to install a T5.
I have everything still except for wiring. I am still determining what wires are to stay w/ my car and converted for the manual vs which ones are now "extra" and need to come out.
The steering column has a lock mechanism w/ cable that goes to the shifter that locks the shifter in Park unless the key is inserted and unlocked. I am not sure if that feature exists on all steering colums (obviously doesn't lock the manual shifter). But, it involved a cable that ran from the base of the column to the shifter mechanism.
That feature is probably not required, but I guess an added safety feature for the Automatics.
Your transmission fluid is cooled by separate passages in the radiator. There is a pair small metal pipes that run under the passenger side of the engine to the radiator. Mine were rusted/siezed up, so I cut them when removing. I am not sure if GM installed a different radiator for the manual and automatic cars. The ports on mine are on the passenger side of the radiator. I think the radiators are generally transmission specific.
I'm in SE Virginia if you wanted to try a one stop pickup for all or most of the parts.
Ken
Old May 15, 2020 | 12:47 PM
OrangeBird's Avatar
Car: 1989 Firebird
Ya both coulda saved yourselves boatloads of trouble by just trading the whole cars themselves VS the major mechanical bits & pieces .....
Old May 15, 2020 | 01:06 PM
ken23434's Avatar
Car: 1986 Z-28
Engine: LB9
But, he probably won't like the status of my car...
Old May 15, 2020 | 01:11 PM
ken23434's Avatar
Car: 1986 Z-28
Engine: LB9
Here is a pic of the lock mechanism on the bottom of the column...
Old Mar 2, 2021 | 03:14 PM
jbalzola's Avatar
Car: 1984 Pontiac Firebird
Engine: none atm
Axle/Gears: 3:73 zexel torsen
I have an 84 trans am that's an automatic and I need to replace the column because the guy who had it before me screwed up the guts of it and destroyed the collar. I have a steering column from another 84 but it is from a manual car. Can I swap that in as is or will I have to change parts out?
Joe Stephens
May 15, 2020 01:08 PM
Ilike2stroke383
Feb 27, 2010 11:12 AM
goomaan
Aug 13, 2007 11:32 AM
doc
Oct 5, 2006 12:49 AM
