automatic shifter 4 700r4
Old Dec 17, 2012 | 12:46 AM
Joe Stephens's Avatar
Car: 1986 camaro
Engine: 2.8
Transmission: T-5 5speed
i want to get a shifter that would work with a 700R4 transmission cause i think thats what i have not really sure. i heard these http://www.4wheelparts.com/Drivetrai...FQf0nAodER0APA work with the 700r4. Does it work without much problem or can i use this?
http://shop.advanceautoparts.com/web...ntent=17130151
Old Dec 18, 2012 | 06:58 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
They make a console version of the megashifter also. It includes new metal brackets, trim plate, indicator selection, and shifter boot. That may be a better choice. That being said they install fairly easy. They should also come with a new shifter cable bracket and a new cable. The oem ones won't work without modification. You also need to wire up the neutral switch and reverse lighting but thats not hard. I've done it a few times now.
Posted from Thirdgen.org App for Android
Old May 15, 2020 | 01:08 PM
ken23434's Avatar
Car: 1986 Z-28
Engine: LB9
Re: automatic shifter 4 700r4
Mispost
Shaz
Sep 27, 2016 02:24 PM
neilb
Sep 13, 2012 09:28 PM
Imadude_134
Dec 3, 2007 12:33 AM
blk89 5.7liter
Jun 30, 2006 12:00 PM
