88 gta t56 question
Old May 18, 2020 | 08:07 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
88 gta t56 question
I put it a used 95 lt1 t56 in my gta in place of the t5
and every since I did this when I'm in gear the car vibrates pretty good when I'm accelerating hard
the tranny works fine had some input shaft play up and down 170kms or 110miles
now I got a spoon transmission crossmenber mount
and I have a 2002 aluminum rear driveshaft
that I got used 4 years ago and never vibrated
is it possible it's really to tight in the t56 housing making it vibrate
or is it ok like that .
and I just used the t56 torque arm to
stock one
do I need to get a adjusting one and set the angles
will that fix it
Old May 18, 2020 | 08:28 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 88 gta t56 question
^^^ This would be my best guess.
Make sure the trans mount and torque arm mount are good and tight and not needing fixing. And measure u-joint angles. Correct by adjusting the pinion angle by either shimming trans mount, or using an adjustable torque arm.
Old May 18, 2020 | 09:12 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Any clearance problems with the bigger gearbox under there? Anything in the drive line hitting the floor pan will sure make for some nasty vibration and noise with acceleration.
Old May 18, 2020 | 10:44 PM
bensbaby's Avatar
Engine: 383 built
I cut it out with a grinder to make sure it cleared
I think I need to adjust the driveshaft angle
Old May 19, 2020 | 07:38 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
balance issues with the stock style pp are fairly common with the T56.
Old May 19, 2020 | 12:57 PM
bensbaby's Avatar
Engine: 383 built
it was replaced 1 time before I bought it
it was so new it still had the paper sticker on the disc
I will keep that in mind
I ordered a magnetic base angle finder and I'm gonna see if it's out of whack
That's my first thing
Old Jun 15, 2020 | 04:07 PM
Diabeetus_Prime's Avatar
Car: 1989 Trans Am 60k Miles
Engine: 305 TPI 210/218 cam and V3Si blower
Transmission: T56 Swap
Axle/Gears: 10 Bolt w/Yukon Duragrip and 3.73s
Ever come to a conclusion? I'm experiencing a vibration issue with my T56 swap even after getting the flywheel and clutch balanced.
92camarors5spd
Apr 17, 2011 09:28 PM
MATEOZ28
Aug 7, 2002 10:17 PM
F22Raptor
May 17, 2001 12:56 PM
