t56 over all length?
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
here is my question. what is the overall length of a lt1 version t56? from bellhousing to tailshaft. and also you can use your t5 driveshaft and torque arm with a lt1 t56 correct?
Car: 90 camaro (92 z28 clone)
Engine: 383 475hp @ 6200 480tq @4000
Transmission: T56 six speed
well excuse me, maybe I should have researched you question a little harder
can you tell me why that site sucks?
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
haha. it doesnt suck. but its not completely accurate. one thing ive read thats not right is 93 and up has a .5 6th gear? its actually 98 and up. and he says that ls1 swaps are so much harder to swap? there not its actually easier. why would you changed a push style ls1 t56 to a pull lt1 t56? its just the little tihngs really. but whatever my t56 will be in soon. and i wont have to shorten my driveshaft or torque arm.
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
before you do yours check this company out. weirhotrodproducts.com/id2.html they have the nicest kit ive seen. and i will be using this kit.
Car: 86 Regal Limited
Engine: 95 cop lt1
Transmission: t56
Axle/Gears: 8.5" gn/3.73 gears
Re: t56 over all length?
1993 3.36 2.07 1.35 1.00 0.80 0.62 (std)
1993 2.97 2.07 1.43 1.00 0.80 0.62 (G92)
1994+ 2.66 1.78 1.30 1.00 0.74 0.50
http://www.tacreationsusa.com/manual_trans.htm
sorry, was trigger happy and forgot the check the date on this before i replied. found it via search. ignore the jacka$$ hahahaa.
Last edited by dyrt; Apr 17, 2011 at 06:10 PM. Reason: didn't look at date....duh...
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
Brought this one back from the dead, did you? I'll add a little for clarity in future search results. >.o
'93 was the ONLY year of the F-body T56 that did not have the .5:1 6th gear ratio. Dyrt's specs are right on the money as far as that goes. And using an LS1-style trans in a car with an older ('97 or before) genI or genII SBC engine is not so easy at all. It requires an adapter plate between the engine and trans (bellhousing bolt patterns are different) as well as shortening the driveshaft. The LT1 trans is practically a bolt-in swap.
Misinformation is bad.
bigjay89gta
Oct 15, 2015 08:04 AM
