Clutch splines
Old May 28, 2020 | 07:52 PM
Benett Bauer's Avatar
Clutch splines
I have a 1985 Pontiac Firebird sbc 350 and I want to put a t5 behind it I have found a t5 with a 10 spline output shaft is there a clutch assembly that would work with the 350
Old May 28, 2020 | 08:04 PM
Drew's Avatar
Re: Clutch splines
10 spline input would be a V6 trans, or a Mustang. Might as well just kick yourself in the nuts now, rather than trying to make that trans work. It might work briefly, but they're borderline junk when it's a V8 T5 behind a 305. A V6 T5 behind a 350, you're just asking for trouble. The way you'd do it, is a V8 bellhousing with a custom clutch disc, assuming it's a V6 thirdgen trans. If it's a Mustang trans or S10 trans, the shifter will be in the wrong place and there won't be a torque arm mount. Just aw hell naw to that entire idea.
Racca116
Mar 2, 2018 06:41 AM
maroon88iroc
Nov 18, 2008 06:58 AM
trans1973
Jun 12, 2006 12:07 AM
Cronic3rd
Sep 22, 2003 09:54 PM
