Bad carrier?
Old Jun 25, 2020 | 07:53 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Bad carrier?
With car jacked up rear wheels off ground manual trans in gear i can spin the rear wheels of the car and driveshaft doesn’t move is this correct?? I did a pull with my new 408 Lsx /t56 afterwards noticed vibration from rear and jacked up to check things out
Old Jun 25, 2020 | 08:08 PM
BIRD91ZRAG's Avatar
Re: Bad carrier?
If you turn one rear tire clockwise, does the other one turn counter-clockwise??
Old Jun 25, 2020 | 08:11 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Re: Bad carrier?
yes it does
Old Jun 25, 2020 | 08:46 PM
BIRD91ZRAG's Avatar
Re: Bad carrier?
Then everything is working as it should, except if you have a clutch type posi unit, then it's just worn out. Not saying something isn't worn or there's other issues...but it functions correctly.
Old Jun 25, 2020 | 08:47 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Re: Bad carrier?
thanks
Old Jun 26, 2020 | 10:21 AM
Re: Bad carrier?
Yup... an "open" (unlimited slip) one, or one with a typical Auburn "posi" (limited slip) the majority of which are totally worn out and non-functional, or for that matter an Eaton Gov-Bomb "posi" as long as you don't turn the wheel too fast (it's easily possible to spin a wheel fast enough by hand to lock up a Grenade-Lock), will do that.
richw40
May 3, 2013 11:09 PM
jminton
Jul 5, 2012 07:24 AM
jamesbob02
Jul 26, 2003 07:57 PM
Kandied91z
May 12, 2003 02:35 AM
redrs89
Aug 5, 2002 07:56 AM
