Can I re-index the pressure plate without removing the transmission?
Old Jul 2, 2020 | 10:20 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
L98 with stock T5 WC. All stock stuff. I was thinking I could remove the starter and access the pressure plate bolts through the inspection cover. I THINK I can rotate the pressure plate to some different holes and reinstall the bolts. I know I would have to rotate the engine a bunch as I work the bolts but this seems a lot less work than removing the transmission. Anyone tried this?
Old Jul 2, 2020 | 10:31 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Can I re-index the pressure plate without removing the transmission?
No don't try that.
Old Jul 2, 2020 | 01:52 PM
GeneralDisorder's Avatar
Very bad idea. Don't do that. Besides the pressure plate potentially getting bound up with bell-housing, the throw-out bearing/fork/pivot ball will likely severely limit and complicate the situation.
GD
Old Jul 2, 2020 | 02:40 PM
Engine: 350 TPI L98
Transmission: WC T5
Dang. Well it's tranny out then. Thanks.
OddJack
May 20, 2010 05:44 PM
bomberpilot07
May 15, 2010 06:37 PM
JTNKTZ
May 1, 2010 08:35 PM
cal30_sniper
Feb 22, 2010 03:07 PM
firechicken_3
Aug 24, 2002 06:43 PM
