Will grade 8 bolts be fine with tranny to bellhousing and pressure plate bolts?
Old Apr 29, 2010 | 08:12 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Title.
If not help?
Old Apr 29, 2010 | 11:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Will grade 8 bolts be fine with tranny to bellhousing and pressure plate bolts?
Bellhousing bolts only need to be grade 5. Torque converter bolts should be grade 8. Pressure plate bolts "should" be grade 8 with grade 8 lock washers.
Old Apr 30, 2010 | 07:01 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Can't go wrong with using Grade "8" fasteners. Just will cost you more.
Old May 1, 2010 | 03:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Any good bolt really will work for the bellhousing, but I'd just get the right clutch hardware from ARP or GM.
Old May 1, 2010 | 08:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yes, the flywheel bolts in particular usually have thinner heads to clear the clutch. normal hex bolt head and washers will probably hit.
I use grade 8 for everything, really no reason for grade 5, unless its a part that needs to shear before something more important breaks. The price is not much different
BlackphantomZ28
Apr 24, 2016 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
mhatfield 14
Oct 24, 2015 07:48 AM
383backinblack
Aug 15, 2015 06:36 PM
Kaweh
Aug 9, 2015 02:54 PM
