transmission question
Old Jan 14, 2002 | 10:06 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I have the 4-speed auto and heard of people saying that they manually shift with the auto. Can you do this? How? Do you put it in 1 then shift to 2? What happens after 2? My shift selector says P R N OD D 2 1. By shifting manually does it hurt anything?
Old Jan 15, 2002 | 11:00 PM
trans87's Avatar
Nobody here has done this before? Come on I know you have
Old Jan 16, 2002 | 03:59 AM
transfixleo's Avatar
Yes I have, yes you can. You need to check your line pressure in D2 and D1. They should be the same as the max pressure in O/D and D, if not replace the Int/Rev boost with a larger one. If you do that then also install a TransGo Shift Kit/Reprogramming Kit.
Old Jan 16, 2002 | 07:14 PM
trans87's Avatar
So how do you shift? Do you have to let go of the gas or anything? Do you just push it to the next gear? What happens after you shift into 2? Do you move it to D? Or do you move it to OD?
Old Jan 16, 2002 | 07:23 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
after 2 you shift into "D" which is 3rd gear. After "D" you switch to "OD" which is 4'th gear.
Old Jan 17, 2002 | 04:14 AM
After you have done the checks/changes I mentioned then you just keep moving the shifter as you want it to shift.
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
redmaroz
Aug 16, 2015 11:40 PM
