Torque arm help
Old Oct 21, 2020 | 12:49 PM
Bobby James's Avatar
Torque arm help
Bought a new torque arm for my 82 camaro 406 700r4. Read on the jegs website that i need a 85 or newer torque arm mount “clamshell mount”. Got one off a 99 doesnt fit. I would start drilling holes to make it fit but dont want to mess up pinion angle. Any advice?
Old Oct 21, 2020 | 01:52 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Torque arm help
Just buy the new correct bushing. They aren't expensive.
Old Oct 23, 2020 | 01:31 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Torque arm help
The right later "bushing" should fit a stock shell as stated above.
Is there any chance the '99 mount you got was from a manual?
Old Oct 24, 2020 | 06:53 PM
Re: Torque arm help
Exactly in what way does it "not fit"?
A manual one won't fit an auto trans or vice-versa. In the 3rd gen there's also the difference in which way the TA stamping faces (no idea whose brilliant idea that was): it can either be a "3" vs an "E". (or "W" vs "M") Not sure if the 4th gen has that as well but I kinda don't think so.
Old Oct 24, 2020 | 08:06 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Torque arm help
I don't know what you've got ( the Torque Arm or the bracket) but from what you posted; it sounds like you'll need the 82-85 brackets and bushings. POST SOME PICS so we can give you the best advise based on facts and we're not guessing !!!
The earlier design bracket has a "notch" in it and I'm pretty sure the 86+ bushings will not properly fit in the earlier 82-85 brackets. While this pic shows T5 brackets,... I'm fairly certain the auto brackets are made the same way (with a notch ). 82-85 on the LEFT ( Torque Arm "lips"facing pass side) and 86+ on the RIGHT. (Torque Arm "lips" facing the drivers side. )
Old Oct 24, 2020 | 08:13 PM
Re: Torque arm help
Just wanted to point out that you guys forgot to put quotes around "bushing" like jmd did. Don't know why, but he feels we need quotes.
esc
Aug 22, 2023 05:04 PM
steve90rs
May 26, 2011 10:00 PM
Rajin
Sep 19, 2010 06:56 AM
Gta-Paladin
Aug 30, 2002 09:10 PM
