Driveshaft Clearance to e brake bracket.
Old Oct 22, 2020 | 05:15 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Just put in my new driveshaft from Driveshaft specialist in TX. 3 inch steel with 1350 joints. Just wondering on the clearance to the ebrake cable bracket. Pic for reference
its on the side of driveshaft about 3/4 inch away. Dont think the ds has that much side to side movement but have to ask. Thanks
Old Oct 23, 2020 | 08:13 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Driveshaft Clearance to e brake bracket.
Shouldn't be a problem. If you get 3/4" play in the shaft there you have bigger transmission or rear end mount issues.
Old Oct 23, 2020 | 12:55 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Kinda figured the side to side would not be an issue. Thanks for answering my question. Maybe you can answer this one. Nhra approved loop in the front, 2inch wide x 4 inch diameter withing 6 inches of u-joint. My fab guy says the front of the driveshaft in relation to the back moves very little in terms of suspension arc. I have about 3/4 inch top and bottom of shaft, plus I'm on heim joints so its pretty solid. Thank you
//<86TA>\\
May 22, 2010 02:07 PM
Warrior
Jan 13, 2010 08:34 AM
DigiTalZ28
Jun 28, 2002 01:56 PM
poncho9789
Feb 26, 2002 05:56 PM
Mkos1980
Sep 7, 2001 02:13 PM
