Adding Torque Arm to GM 12 bolt?
Old Oct 31, 2020 | 10:27 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So my car has a GM 12 bolt rear end from a car. Its definitely not a truck rear end. The previous owner installed mini ladder bars to the sub frame connector, which I assume was done because there was no torque arm. Does anyone know of a company that makes a bracket or anything so I can add a torque arm to the diff and go back to using lca instead of ladder bars?
Old Nov 5, 2020 | 06:10 AM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Re: Adding Torque Arm to GM 12 bolt?
Nothing off the shelf. Possible you could have a good fabricator mimic a mount like the 8.8 swaps use. Could do a DSE quadralink as well I believe. Wouldn't use a torque arm, but would probably work better than ladder bars on a street car. Other option may be buy a bare 12 bolt swap housing and swap your parts over.
None of the options are gonna be cheep
Old Nov 7, 2020 | 02:45 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
https://www.thirdgen.org/forums/memb...oming-aka.html start around post 849.
Also, see what GM did to fit a torque arm to the Buick GNX, which got a torque arm using a cast rear cover. (vs the Grand National and Turbo T which had hotchkis style 4 trailing arms.)
TxTtopZ
Apr 2, 2015 02:01 PM
Thomas Aquinas
Oct 10, 2011 12:45 PM
weitz
Jun 27, 2008 12:08 AM
