Moser 9 inch Torque arm bracket
Old Mar 6, 2008 | 09:49 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Anybody with a Moser 9 in have any problems with the torque arm bracket holes not lining up? It bolted up to the rear no problem, but the holes for the torque arm aren't lining up. Its a spohn torque arm and it bolted in perfect on my old 10 bolt. I can get the rear bolt through, but then the front bolt is off. With the LCAs off I can get the front one in, but then the whole rear is angled with the car. I can probably put the LCAs (adjustable spohn pieces) in and use them to square things up, but I don't want to put any twisting where there shouldn't be.
Anyway, can anyone share there experiences?
Thanks.
Old Mar 6, 2008 | 11:21 AM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: Moser 9 inch Torque arm bracket
Sounds like somthing is off. I just put a moser 9 inch in with my spohn torque arm. I had a hell of a time getting the two bolts to line up, but playing with the pinion angle adjustment on the torque arm and jacking the rear end up from different angles (jacked under the drivers side, passenger, and middle of the rear at differents times)I was able to get it. OH, and it took about an hour or two with help.
Old Mar 6, 2008 | 11:39 AM
Car: 1986 Iroc
Engine: Afr 408
Thanks for the response man. Yea, I can get the other bolt in, but things look a little out of alignment. The adjustable LCAs, torque arm, and panhard will help, but I just don't want to but any weird stresses in places there not supposed to be. It was definitely more of a struggle than with my 10 bolt.
It also doesn't help that I have brand new springs too. The damn torque arm wants to fly through the floor.
Thanks again.
Old Mar 6, 2008 | 11:59 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
assemble the rear with the springs out and they should be the last thing bolted on....
Old Mar 6, 2008 | 01:42 PM
Car: 1986 Iroc
Engine: Afr 408
With the springs out, it might be easier to line stuff up.
Wouldn't the shocks be the last thing bolted on though? So I might have better luck with the springs and shocks off, then assemble everything, then put the spings in followed by the shocks? Is that what you did?
Old Oct 10, 2011 | 11:57 AM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Just wondering if you guys can help me. I installed a moser 9 this weekend had problems with stock torque arm fitting but after making the torque arm holes a little bigger it fit but now my car shakes at 40mph more when i let go off the gas but at 50 its both are bad. What can it be please help... I also had problems with the stock panhard the bushings were to big but when i hammered them in one rubber bushing broke. Idk if that can make it happen.
Its a moser 9"
35 spline axles
4.11s
Old Oct 10, 2011 | 12:24 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Tighten all the suspension? Stock driveshaft?
Old Oct 10, 2011 | 12:45 PM
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Yes we tigheten everything i will jack it back up today and check but im 95% sure everything is good. But yes the driveshaft is stock!!
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
