83 Trans Am Rearend
83 Trans Am Rearend
I have the opportunity to buy a 83 trans am rear end. Owner says it's a borg warner 10 bolt 3.73 gears posi. Also has disc brakes. Would this have come stock on this car? Was in a 305 5 speed car. Is this a desirable rear end? Thanks for any help.
Engine: 5.7 L98
Re: 83 Trans Am Rearend
That is a desirable set up and was available on an 83’, probably a WS6 or L69. The early WS6/L69 cars had better gears than the later cars barring G92 IMO. 3.42 or 3.73 are nice gears in these cars and a good upgrade.
The Borg Warner is a 9 bolt. If it's a 10 bolt rear cover then it's just a standard GM 10 bolt. Nothing special. Even the 9 bolt isn't that special without upgrades.
GD
GD
Engine: 5.7 L98
If it’s a mostly stock car it would give you a good seat of the pants increase. You have highway gears in your car now which I assumed earlier and if you put those 3.73s in there it would pick up down low for sure and spin the tires much better lol. It would make it a nice street cruiser and liven it up.
Lot of guys on here say basic mods, increased stall converter and a gear swap like that can give a boost of performance for not a lot of money. It really depends on your plans for your car, ability and budget.
That being said If you plan on swapping to a different motor like LS and going for a real high performance build I wouldn’t bother with it IMO.
Engine: 5.7 L98
Keep us posted on here, it will feel like a different car if you swap. Do you have any idea what kind of condition it is in?
Yeah depends on condition. The posi cones are probably shot on both yours and this 83. A Torsen upgrade could fix that. It would be a 3.70, not a 3.73, and your factory would be a 2.77 not a 2.73
GD
GD
Car: 89 Firebird
Engine: 355 TBI
I'd rather have a 9 bolt but anything numerically lower than 3.23 gears in these cars just make them sluggish.. period. 3.23- 3.73s is where you wanna be.
Car: 89 Firebird
Engine: 355 TBI
I pulled a 10 bolt Posi 3.73 rear from a friend's wrecked 83 or 84 L69 5spd car and that is what I'm currently running. I didn't think the 9 bolt Borg Warners were out then but I may be wrong. They were much stronger rears I've ran them before when 10 bolts didn't hold up.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
There is no difference in strength between the 9 bolt and 10 bolt...
The 9-bolt didn't appear until 85 in FIrebird and 87 in Camaro. No 9-bolt was factory-installed in a 83. Now, in the ensuing ... almost 40 years, who knows. It was somewhat of an upgrade over the 10-bolt in terms of "strength" but it comes with its own list of problems. (ahem: opportunities for solutions)
Assuming that this REALLY IS a 83 rear, it's a 10-bolt. It's got the weenie 26-spline axles, the crappy Auburn posi that is almost certainly dead, and the crappy Saginaw disc brakes that are usually less functional than drums. I would NOT classify it as "desirable" in any manner way shape form or fashion, except as something to put under a body that was missing a rear so that I could tow it.
A set of 3.73 gears NEW is right around $200. I would only pay LESS THAN ZERO for a 40-yr-old set. Which is to say, I would pay somebody to come haul them away. Same for the Auburn posi and the Saggy disc brakes and the pencil-d*** axles: I would pay somebody to keep them, if that was the only way to avoid them cluttering my property; or to come take them away, if they inadvertently found their way there against my will.
I would recommend NOT buying that POS.
Car: '89 GTA
Engine: ZZ6TPI
GD
Car: '89 GTA
Engine: ZZ6TPI
GD
Car: '89 GTA
Engine: ZZ6TPI
I’m talking more about optimizing for 1/4 mile trap speed when I say 3.73’s are too much gear for a stock 350TPI’s RPM range.
A little more. It's a FIRST TPI. Peak HP is 4700, but it does pull to 6500. I have the governor shifting at 5k though. The power delivery is pretty flat.
GD
GD
Car: '89 GTA
Engine: ZZ6TPI
Car: 89 Firebird
Engine: 355 TBI
