trans leak
Old Nov 30, 2020 | 01:36 PM
shorin21's Avatar
trans leak
Hey all,
just picked up an 85 z28 with a 700r4. we ran it for about 4 months this summer to have zero leaks, once it started to get cold out the leak started. It is coming from the 2 bottom pump bolts. my question is do the bolts have o-rings and washers or nothing but torque to hold them in...
thanks
jake
Old Nov 30, 2020 | 02:45 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: trans leak
Yes, there's rubber o-rings around the pump bolts.
Old Nov 30, 2020 | 02:57 PM
Shorin8553's Avatar
Re: trans leak
Ugh ok someone else told me its just the bolt and washer ill use them too
Old Nov 30, 2020 | 03:01 PM
Shorin8553's Avatar
Re: trans leak
Do I need to pull the trans or can I just yank those two bolts out and add the new oring and washer
Old Nov 30, 2020 | 03:14 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Re: trans leak
Sure, you can replace the o-rings on those bolts. As long as they clear the converter. There's a washer and o-ring used on each bolt.
Icantthinkofone
Jul 7, 2013 08:22 AM
dmock
Jun 21, 2009 05:47 PM
DOOSKI
Nov 8, 2003 01:17 PM
