B&M shifter Neutral switch problem
Old Dec 6, 2020 | 05:52 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So I recently installed a B&M shifter. The one that is made for our cars. In the wiring for the relay, it said to use a yellow wire, but my wire was green. I am pretty sure it was wired correctly, yet the safety switch would not work with the relay. I ended up just running the purple and green wire off the bottom switch and it started fine. Anyone else ever have this problem?
Also, does anyone know which color wire goes the ecm to tell it whether it is in drive or park?
Old Dec 7, 2020 | 09:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: B&M shifter Neutral switch problem
ORG/BLK to ECM terminal B10
RBob.
whiskypig475
Feb 26, 2013 04:09 PM
SS ninja
Jun 14, 2007 08:55 AM
DuStangz
Apr 25, 2006 07:05 PM
link85x
Mar 25, 2006 09:12 AM
CamaroEFI
Nov 14, 2002 10:14 PM
