TH 400 issues after shift kit install
Old Dec 20, 2020 | 06:52 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Running a 65 TH400 the early design with a box filter. Good overall condition and just installed a Transgo 1-2 kit. After install the trans shifts great in "D". Going into reverse it is slow to take gear and seems weak but doesn't slip once in gear. The other issue is when in L1 it feels like it's in 1 & 2. It pulls but has a noticeable drag. What could I have installed wrong when installing a shift kit to have the symptoms like this?
Old Dec 29, 2020 | 11:15 PM
vorteciroc's Avatar
Top Answer: 1
Re: TH 400 issues after shift kit install
It sounds like the TransGo separator plate (sandwich style) may be leaking between the layers...
It is possible for reverse to engage softer, even if the plate is good.
This plate dual-feeds the direct clutch; making reverse apply softer/ slower if the feed orifice is not enlarged (especially if the 3rd accumulator is not deleted).
However it sounds like the separator plate may be leaking between the layers causing another clutch to drag in L1.
I would try to re-install the original plate or a new stock type plate.
JP007
Oct 10, 2010 08:30 AM
snapsmagee2000
Dec 13, 2005 05:44 PM
burn0ut305
Jan 14, 2005 07:53 AM
naachoo
Sep 6, 2002 10:08 PM
Twilightoptics
Oct 17, 2001 03:08 AM
