Knocking from bell housing area
Old Dec 28, 2020 | 08:51 PM
Spankypickles9's Avatar
Car: 1984 Camaro Z28
Hey everyone, just gave my car a good run up and down my road and finally managed to get it to let me catch this noise on video. It doesn’t always do it and I have yet after years of driving it been able to find out what it is because when I want to check it out...it won’t do it!! I have a video I’ll post but I’ll describe it. When sitting in the car you can hear it, it sounds like a knock coming from behind the radio area/bell housing area of the tunnel. With the car in park or neutral, you can hear it and it is steady with the rpm. So when it’s idle, it’s slow and when you rev the engine it speeds up. When you put the car in gear, it goes away completely forward and reverse even when you give a little rev. From the outside of the car (i don’t have any means of lifting it at the moment) just sticking my head under the car I can very faintly hear it if I go under right around where the mirrors are. Cannot hear it at all in the engine bay. In all honesty it sounds like if there was no bell housing is sounds like something riding around the flywheel/input shaft and slapping the tunnel! Any ideas/diagnostic steps would be greatly appreciated!
Video:
Old Dec 28, 2020 | 10:37 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Knocking from bell housing area
Need to get under there and check those torque converter bolts, and look at them close for marks that indicate the heads might be hitting the back of the block, close tolerance there.
Old Dec 29, 2020 | 01:39 PM
OrangeBird's Avatar
Car: 1989 Firebird
Old Dec 29, 2020 | 02:21 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Based on your description, you're looking at either loose flex plate-to crank bolts, loose torque-convertor-to flex plate bolts, or possibly a cracked flex plate.
soulbounder
South Central Region
Aug 21, 2019 09:55 PM
Diggler86
Dec 4, 2014 11:44 AM
Banks4004
Jun 15, 2013 06:22 PM
RWO3
Sep 7, 2012 04:12 AM
