speedometer reads off
Old Jan 30, 2021 | 07:44 AM
indygene's Avatar
Car: 1982 Chevrolet Camaro Indy Pace Car
Hello I have an 82 Camaro Z28 it has the 140 speedometer and a 700r4 transmission i would like to know what speedometer gear set should be used to get the correct reading on the speedometer i am running the factory original gears it has the crossfire injection system
Old Feb 5, 2021 | 12:49 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: speedometer reads off
based on the following, a 2.73 car had 17t drive with 37 or 38, depending on stock tires. and a 3.08 rear car had 41 or 42. I think you might have 2.93 ( but double check) in which 39 or 40 would work. It is a very good idea to verify what gears you have in the trans, and at the differential. Also, if the odometer is tallying miles correctly bit the speedo reads off, speedo gears are not required.
https://www.thirdgen.org/forums/atta...9217f_0496.png
Edit; on mobile, didn't see 3.23 in your profile.
17 / 44 or 15 / 39. So, see what speedo drive gear you have (third gens were 15 or 17) and match the driven.
Old Feb 6, 2021 | 02:15 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Yup,..... 17 RED on the tail-shaft & 44 dark GREY on the sending unit for 3.23 and 700R4.
micktroup
May 6, 2019 11:35 PM
91_5.7_TPI
Sep 5, 2005 04:51 PM
