Full Patern Reverse Manual Valve Body
Old Jan 16, 2002 | 12:24 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Does anyone know where I can purchase a Full patern reverse manual valve body 700r4, or a place I can send mine out to get it converted, and a ball park figure on how much it would cost. Thanks
Old Jan 16, 2002 | 09:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm not saying there isn't one made yet but to my knowledge I've never seen one for a 700R4. Supply and demand. Since there's no demand for one because the 700R4 isn't a race tranny, nobody has manufactured one. If they do, it will probably be expensive.
GM tranny manual valve bodies price wise.
Powerglide - very cheap
TH400 - a bit more expensive
TH350 - expensive
700R4 - ???
Even companies like www.turboaction.com who have made valve bodies for racers for years don't have one yet.
Old Jan 17, 2002 | 12:10 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Thanks for the help, I was just curious to see if they made one or not for it, because id really like to have one in my car, but Id still like to be able to drive the car quite a bit on the street, and not having an overdrive will hurt especially with a 4.10 in the back
Old Jan 17, 2002 | 07:47 PM
Cosmik Debris's Avatar
TCI make a full manual for the 700R4 not sure if it is reverse or not though. The TCI kit does not use the TV cable to control the line pressure so shifts are always hard. There is also no engine braking i.e. the car free wheels when you take your foot off of the gas.
The Trans Go kit also has a full manual option. This just removes the governor.
Old Jan 17, 2002 | 08:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Well hey look at that.
http://www.tciauto.com/valve_bodies.htm
A manual reverse pattern valve body for a 700R4. Have fun.
Old Jan 18, 2002 | 12:03 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Im just curious if its alright to drive around town with a manual valve body transmission or is too much for it to handle?
Old Jan 18, 2002 | 05:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
They're not really recommended for the street. Although you have to shift through every gear, you can also wear out parts quickly by starting off in third gear too much. The other drawback is that there's no engine braking in first or second gear. That means when you lift off the gas pedel while in first or second, the tranny will just freewheel and the engine doesn't help slow it down. You'll have to rely on the brakes more.
Drive up quickly behind someone then lift off the gas to match their speed. Engine braking slows you down when you lift. With no engine braking you'll keep rolling at that speed until road friction or stepping on the brakes slows you down.
This isn't a problem in a race car either drag or oval racing where manual valve bodies are used a lot.
Old Jan 22, 2002 | 10:32 PM
Bob86ZZ4's Avatar
I have a revearse pattern manual valve body 700r4 in my car. Actually it's now laying on my garage floor cuz it disintigrated after 5000 miles. Art Carr said it would last forever, hahahahaha. I just talked to them about my problems and they are going to try to work out some sort of solution for me, I have my fingers crossed. I'm converting to a manual valve body TH400 with a Gear Vendors overdrive.
Old Jan 24, 2002 | 12:32 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
thats really ****y that happened Im probably better off with a shift kit or what not, I just want better shifts, cause it seems like the stock 700r4 is slow between shifts
Old Jan 24, 2002 | 04:16 AM
transfixleo's Avatar
IMO, the manual setup is not good for the street. It is not like driving a standard and forget once or twice to bring it down to the right gear and Poof! There goes your tranny. For a solid, dependable tranny use the TransGo Reprogramming Kit.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
