VSS code 24 not answered in other threads
Old May 13, 2021 | 01:40 PM
Voodoodaddy's Avatar
Car: 1990 firebird formula
Engine: 355 tpi
Long story short I have a 1990 formula with a built 355 and 700r4. Already swapped vss and code still persists. Speedo is electronic and doesn't work. Is the code just trying to tell me the speedo is faulty or are there other mechanical or engine related issues I should be worried about. With the exception of the speedo not working, the car runs like a dream. Thanks in advance. Pic of new vss same as old one pulled from transmission
Old May 13, 2021 | 03:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VSS code 24 not answered in other threads
You can measure voltage while driving at Vss buffer or ecm depends on what the car is or was tpi, v6 or tbi.
Old May 13, 2021 | 03:25 PM
Engine: Lb9
Transmission: M20
https://m.youtube.com/watch?time_con...b_title#dialog
Old May 13, 2021 | 03:38 PM
Engine: 355 tpi
It was a 350 tpi with ecm and no buffer. Still tpi
Old May 13, 2021 | 03:42 PM
Engine: Lb9
Transmission: M20
Check at b9 and b10 at the ecm yellow and purple white.
backprobe and drive looking to see if there is a signal. Yellow is signal purple is signal ground.
Old May 13, 2021 | 03:59 PM
Engine: 355 tpi
Rock on. In the meantime what are the mechanical ramifications of driving with a faulty vss. She seems to shift and accel fine
Old May 13, 2021 | 04:03 PM
Engine: Lb9
Transmission: M20
You could get stalling on deceleration and no tcc lockup.
Old May 13, 2021 | 04:17 PM
Engine: 355 tpi
Noted. I'll be on the lookout for those. Thank you
DBRjeep350TPI
Aug 7, 2012 11:17 AM
fire350tpi
Aug 21, 2006 11:09 PM
anesthes
Aug 23, 2005 05:54 AM
92 zzz28
18
Sep 16, 2003 10:30 AM
c3go_92RS
Nov 29, 2000 11:44 PM
