Eaton True Track Backlash Shudder
Old May 22, 2021 | 06:44 AM
luca's Avatar
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
I installed a eaton true trac unit on my firebird and have a excessive clunking sound every time I shift . it feels like there is a lot of slop at the internals of the diff
but when i turn the driveshaft with the wheels on the floor it is only like 8mm left to right
backlash is set correctly and the rear is silent on the highway
u joints are also new so as trans mount and suspension bushings
i greased the splines of the driveshaft witch goes into the trans with a heavy duty grease, it helped a little bit
used 85w90 gl5 mineral oil , should i try a thicker sae140 ? i only drive in the summer
hope someone can help thanks
Old May 22, 2021 | 02:50 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Eaton True Track Backlash Shudder
Thicker lube won't benefit or protect anything better in a 3500lb light-duty application.
Easiest to troubleshoot, with most likelihood to cuase clunking? Trans. mount. Poly especially can transmit more NVH than rubber. Trailing arm bushings can too, but they're farther away, and more work to change.
3ZMan
Nov 13, 2007 11:23 PM
Zig
Oct 23, 2006 10:28 AM
LoudmouthSS
Mar 21, 2006 11:59 AM
Darkness
Apr 30, 2004 07:13 PM
Luther6704
Aug 6, 2003 05:33 PM
