T5 5th Gear
Old Jun 28, 2021 | 06:34 PM
mooses8801's Avatar
Car: 92 Z28 Convertible 25th Anniversary
Engine: 5.0 LB9
Transmission: 5 speed
T5 5th Gear
Guys can you just replace the counter shaft 5th gear by itself. Here's my issue I don't have access to a press to remove the main small gear. I picked up a rebuilt t5 z spec t5 which works great and the 5th gear is .59 which is way to boggy at 60mph. It currently has a 27 tooth and a 59 tooth. My old WC t5 had .63 5th with 25 and 51 gear counts.(Front bearing failure and cracked the case) From doing the math I think replacing the 59 tooth with my 51 tooth and keeping the 27 tooth main it should give me .63 5th if correct assuming I can just replace to counter shaft gear my itself. My car is just a 305 cruiser and not abused. I know I should put a T56 but it sticks down to low for my lowered car and they are not readily available around here. Thanks
27/55=.49 x 1.29 =.63
Old Jun 28, 2021 | 06:40 PM
Re: T5 5th Gear
Highly doubtful.
Gear ratio is the ratio NOT ONLY of # of teeth, BUT ALSO, of diameter.
You can try it, but don't expect miracles. The teeth may not even touch, let alone, mesh properly.
Old Jul 1, 2021 | 12:23 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 5th Gear
Helical gears don't mix-n-match. Without further detail, the shaft distances are static, so they wouldn't have proper tooth contact.
You'll need the matching drive and driven gears to change 5th gear ratio.
The T5-Z for Mustangs has a 28 spline mainshaft and the GM T5s were 27, so be careful ordering the right parts.
Old Jul 13, 2021 | 09:40 PM
mooses8801's Avatar
Engine: 5.0 LB9
Re: T5 5th Gear
Thanks guys. Took the 5th gear set from my old trans and installed them. No mismatch problems.
Old Jul 14, 2021 | 08:44 PM
Re: T5 5th Gear
Cool.
As A SET, they're mostly interchangeable. As individual gears, ... not so much.
midias
Dec 15, 2012 06:40 AM
WSS6
Jun 18, 2009 07:30 AM
jimmy_mac
Dec 11, 2002 05:13 PM
