Which year did the 28 spline axle start
I would like to know so that i can by one of those slp torsen carriers. And if i did would a 3.42:1 ratio work on one of those, that is three series carrier isnt it???thank you
Car: 4
Engine: 6
Transmission: 5
They started in 88, but the change wasn't complete until 90. 89 up also got the good disk brakes which don't require any changes to the hydraulics except dealing with the metric vs. std lines, unlike the older sisk system which doesn't work very well and uses different hydraulics.
Yes, the 3.42 gear will go right on the 3 series carrier which is what the SLP unit is.
Originally posted by Jza
Pull an axle and count the splines.
It's the best way. You could go through all this discussion only to find out a previous owner swapped an older rear end in and you have 26 spline axles. That happened on a 91 that I was going to grab the rear out of. Pulled the axle, counted the splines (like 5 times), and, hmmm... only 26... Originally posted by Cosmik Debris
I think 27 and 30 refer to the splines in the 700R4 transmission.
You have to pull the rear cover off, the cross pin retaining bolt, the cross pin, one wheel and brake drum to remove an axle. You can always get a used set of 28 spline axles to go with the torsen if you find out you have 26 spline axles.
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
The AUBURN web page says that it started in '89, and I have an '89, so i bought a posi and everything, got it all near installed, and it turned out that mine has 26 spline axles.......so i'd have to say 90, cause my '89 has 26 spline axles.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My belief is the change happened in 1990. All 9-bolts already have 28 spline axles, so we're talking 10-bolts here. Every 88 and 89 car I have seen and heard about on here with a 10-bolt has 26 spline axles. For the 1990 and up cars, GM dropped the 9-bolt and went with the 10-bolt on everything. They also upgraded them to 28 spline axles. But your results may vary, as there's an exception to every rule.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Nine Bolt?
Could somebody please post a pic of a nine bolt, i've never really seen one and am wondering what they look like compared to a ten bolt.
Originally posted by TKD89RS
also didn't the revision of the tranny come with the 28 splines and a auxilary valve body. cuz mine has it so would i also have the new axle.
And no, I doubt the dealer would know. You have to pull apart your rear end and count the splines on the axles. Its a complicated process.
hectre13
Dec 11, 2023 08:14 AM
red90IROCls1
Aug 25, 2015 06:56 AM
