700r4 to TH350 help
Old Sep 15, 2021 | 05:33 PM
jcrobinson's Avatar
Car: '88 Firebird
700r4 to TH350 help
Need some help from the group here. I'm swapping out the 700r4 from my 88 Firebird with a TH350. I was under the impression it would be a pretty straight swap, but the TH350 is definitely shorter (To the tune of about an inch and a half, give or take). Worse yet, the tailhousing on the TH350 does not have the bolts necessary to attach my torque arm bar, But the tailhousing from the 700r4 is entirely too long. What am I missing guys? Thanks for your time. See attached pics. First row is from the 700r4, 2nd row is from the TH350.
700r4
700r4
700r4
700r4
700r4
<HR>
TH350
TH350
TH350
Old Sep 15, 2021 | 05:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 700r4 to TH350 help
You will have to fabricate parts . B&M pn 30299 Images online as reference. Been discontinued for years.
Old Sep 18, 2021 | 07:51 PM
Jrf's Avatar
Jrf
I'm no parts expert here so bear with me on this. I have this swap in my 84, and was able to retain the stock drive shaft and transmission cross member from the 700r4. I believe what you need is a long shaft th350 (this is what I am unsure of....I can't tell you tail shaft lengths so I might be leading you slightly astray here...). You need to take the tail shaft housing from the 700r4 and also use a tail shaft housing spacer/ adapter to make up the difference in tail shaft housing from the shorter 700r4 to the long th350. Unfortunately this causes serious incompatibility issues with the speedo drive and I ended up putting an aem x series gps speedo in the car. Other than that it all bolts up and seems to work fine without any need for fabricating parts. I'll look into the spacer a bit more, I have no idea where I found mine.
Old Sep 18, 2021 | 07:55 PM
Jrf's Avatar
Jrf
https://www.summitracing.com/parts/add-50-8506
This appears to be what I used.
Old Nov 15, 2021 | 01:13 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
D.I.Y. Crossmember Mod for 700R4 to TH350 Swap - Third Generation F-Body Message Boards.
Synful
Jul 5, 2007 08:32 AM
Randy82WS7
Dec 4, 2006 10:46 AM
formula1988
May 29, 2005 09:45 PM
lowbgtRS
Jan 13, 2004 07:26 PM
Milner350
May 9, 2001 12:50 PM
