Can anyone help? Trans mount question
Hi all,
Would anyone be able to show a pic of an original trans mount from an 1988 IROC with 5-spd manual, either mounted or removed from car, but known to be the original?
I'm not sure if the one on my car now is correct for this application.
Thanks !!
Thanks !!
Re: Can anyone help? Trans mount question
Gonna be tough to find just exactly that.
It's yerbasic 2-bolts-up holding it to the trans, one-stud-down going to the crossmember. It was exactly the same as any other such mount for many many years. Auto and stick both. Millions and millions of them around. Dozens of available replacements. Pretty hard to put anything else in its place without a certain amount of work.
What makes you think the one in your car might not be "correct"?
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I did a search for a stock-ish replacement, here is the best I found, others were junk or poly, etc...
NAPA Part #
DTM 6441261
I just checked on Napa and didn't find it, it was many years ago... but you can look...
There is a WHOLE thread talking about this / others ,pics, etc...
https://www.thirdgen.org/forums/tran...on-pics-3.html
I post pics and stuff way at the bottom, long thread...
NAPA Part #
DTM 6441261
88 vert guy
Oct 3, 2020 10:45 AM
