I need a 168 tooth flywheel
Old Dec 14, 2021 | 01:11 AM
88IROCZILLA's Avatar
Car: 88 camaro iroc
Engine: 5.0 TPI
Transmission: 5 spd mannual T5
Axle/Gears: 3.27/ 9 Bolt
I have 92 z28 (5.7) auto trans.(700r4) Does anyone have a part number of a flywheel that's a good replacement?
Will this one work? The design is different from the stock one.
Old Dec 14, 2021 | 09:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: I need a 168 tooth flywheel
Flywheel or flexplate for 700r4 ? 153 ?
Mid you have a 700r4 you need a flexplate
Old Dec 15, 2021 | 07:58 PM
Car: 88 camaro iroc
Engine: 5.0 TPI
ooooh... flexplate got it. Didn't know the difference between both.
Old Jan 16, 2022 | 01:31 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Has your flexplate / starter been changed ?
Stock would have been a 153 tooth with the balance weight on it (Ext balance , 1 pcs RMS crank )
m300slr
Dec 3, 2021 05:34 PM
toolegit86
Jun 19, 2010 12:41 AM
xpbxwrecked1
Mar 30, 2009 10:43 PM
critter2655
Sep 12, 2007 11:43 PM
walrus108
Sep 19, 2005 04:46 PM
