ACDelco Clutch hydraulics- Going to be gettin rare.
Old 05-08-2022, 09:43 AM
knightfire's Avatar
Car: 1984 Trans Am
Transmission: Manual
Axle/Gears: Foley & Richard
After 40-ish years have elapsed on our classic and "antique" vehicles, I seen that the AC Delco clutch hydraulics for our cars have gone on closeout status at Rockauto, so better get them while you can.
Rockauto:
AC Delco Clutch Master Cyl. #18M2131
AC Delco Clutch Slave Cyl. #18F85
The AC Delco parts I received say made in USA and look to be of quality. I'd be inclined to believe them to be OEM parts.
From research on this site, I've also pieced together a stainless steel braided hose setup for the system to replace the plastic line.
Nothing below is confirmed as fitting. This info is given "as researched" only.
All of these will be going to my "just in case they become obsolete" spare parts inventory.
(The special -4AN adapters at Summit seem to be in short supply also.)
Summit:
McLeod Racing Adapter Fittings for Clutch (Straight, -4 AN) #MCL-139026
McLeod Racing Adapter Fittings for Clutch (90 degree, -4 AN) #MCL-139027
McLeod Racing Hydraulic Line for Clutch (-4 AN) #MCL-139100-30
Hope this helps someone.
Old 05-08-2022, 07:49 PM
NoEmissions84TA's Avatar
Re: ACDelco Clutch hydraulics- Going to be gettin rare.
Rumor has it that the new vehicles will no longer have manual transmissions - not even an option.
Old 05-08-2022, 09:00 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Won't be too much longer until new vehicles won't have automatic transmissions either, all CVT belt drives. And I'd guess the torque V8 engines will be only in heavier trucks. Regular vehicles are becoming appliances really quick.
Old 05-08-2022, 10:15 PM
That about sums it up perfectly.
Old 05-09-2022, 09:46 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I might grab a set. IIRC the LUK master was made in the USA and when I replaced mine the Advanceauto replacements were aluminum body instead of factory plastic
Dennis-Z28
02-28-2013 01:25 PM
SheldonZ28
05-28-2009 05:05 PM
Quick Reply: ACDelco Clutch hydraulics- Going to be gettin rare.
