700r4 Coasting Surge
Old May 25, 2022 | 06:14 PM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
I have a 1986 Trans Am with a 305 TPI motor and a 700r4 transmission, both of which are stock. After pulling the transmission and redoing the torque converter seal, I did a transmission service and all is well except for a surging while coasting in overdrive and 3rd gear. The issue is a surge of 400-600rpm between 25 and 50 mph. From other information I can gather, the issue sounds like it's most likely the torque converter slipping in and out of lockup. I do have the 4-prong connector plugged in and it did click, as well as the other connector on the transmission. The TV cable is properly adjusted from what I can tell, and the transmission fluid it at the proper level. What could be my issue?
Old May 26, 2022 | 09:23 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: 700r4 Coasting Surge
The lockup can cause weird problems & they do fail. One of the symptoms is in & out of lockup. Another is that it will stay on permanently.
Old May 28, 2022 | 07:01 AM
What I'm not understanding is why would it be doing this and how do I stop it? It's not an aftermarket lockup kit, everything is factory from what I can tell. So why would it be surging in and out of lockup like that?
Old May 28, 2022 | 03:20 PM
72buickgs's Avatar
Car: 1984 Trans AM
U have to have a new lockup installed probably at a tranny shop.
Old May 28, 2022 | 06:42 PM
vorteciroc's Avatar
Top Answer: 1
The THM700-R4 uses the Cooler Charge Circuit to hold the Torque-Converter Lock-Up Disc off.
This is of course when we do not want the TC Locked.
Something as a simple restriction (or drop in Pressure) of the Cooler Charge Circuit, can cause unwanted Lock-up (intermittent or constant).
Less than the required pressure, will result in the Lock-Up Disc not being held off.
RS Chris
Jul 30, 2015 02:31 PM
DRIVE2FAST
Apr 30, 2012 02:05 PM
NubcaekJack
Mar 18, 2010 11:33 AM
bad_ta_05
May 7, 2003 04:13 PM
