New Clutch T5 making a cricket sound
Subscribe
Jun 11, 2022 | 12:06 PM
Hello, I replaced my clutch, flywheel, etc and throwout bearing last year. Now when driving With clutch out there is a constant slight squeaking that sounds like a cricket that goes away when I put the most slight touch of the clutch pedal. I really want to avoid taking the tranny out for this as all works fine otherwise, just annoying. I’m hoping someone knows wtf this could be?
thanks in advance
Reply 0
Jun 11, 2022 | 12:27 PM
Re: New Clutch T5 making a cricket sound
Something to do with the throwout bearing. More likely not the bearing itself, although it could be.
Did you smear a VERY LIGHT coating of grease on the clutch gear bearing retainer before you put the trans in? Blob some onto the fork pivot ball?
Reply 0
Jun 11, 2022 | 12:30 PM
Hey thanks again! I followed your instructions so I’m sure I did at the time. I’m assuming there isn’t anything I can do without pulling everything apart?
Reply 0
Jul 18, 2022 | 11:38 AM
Quote: Something to do with the throwout bearing. More likely not the bearing itself, although it could be.
any suggestions on what I can do? It’s super annoying. Thanks again.
Reply 0
Aug 1, 2022 | 02:57 PM
Quote: any suggestions on what I can do? It’s super annoying. Thanks again.
ok I got this figured out and it took only 5 mins to fix. So I thought I’d post what I did so it hopefully helps others in the future. It was the pivot ball/ clutch fork. I added some grease, I could get access through the rubber boot. Annoying sound gone! Yay easy fix!!
Reply 2
Subscribe
