**attention transfixleo and others**
Old Jan 19, 2002 | 04:24 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i have been installing a transgo shift kit and when i installed the pressure regulator valve i didn't notice that it fell out. so i put the spring and other parts into the car. now the bushing is above the snap ring but i cant get it back down. and starting the car wont blow it out cuz the valve is not in it. how can i get that bushing out which is probably holding everything up. i tryed double sided tape but not strong enough. i tried a vaccum but didn't work. if i glue something to it i think that would work. then id just clean the glue off and install the valve in this time. do u think that would work.
Old Jan 19, 2002 | 05:46 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
if glue doesn't work, im goin to try to drill it out. can i use my stock bushing or do i need to get the one thats in the kit. are they the same. also if i drill to far i might damage the other parts as well. can i buy just the peices for that valve assembly. drilling seems to be the only way to get it out if i dont want to take out the tranny.
Old Jan 19, 2002 | 06:25 PM
Jay 727's Avatar
I have a 700 on the bench in my garage. Can't think of a way to get it out. Trying to drill it might casue it to spin. Try the largest diameter magnet you can fit on it and work it in and out, it may feel like it's not moving at first but it might work.
Old Jan 19, 2002 | 06:32 PM
Pro Built Automatics's Avatar
If you drill it out I will have it shipped out on Monday (drop ship directly to you). Call me anytime this weekend.
Old Jan 20, 2002 | 03:18 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
thanks for all the help guys. i just drilled it out and order the piece.
ajh87iroc
May 15, 2009 08:51 AM
ChevyLuva3
Feb 5, 2002 07:46 AM
b92z28
Dec 12, 2001 04:37 AM
Dyno Don
Nov 2, 2001 04:10 PM
Eddie
Jun 15, 2001 04:46 PM
