T5 Input Shaft Interference?
Old Jul 31, 2022 | 09:34 PM
thainglo's Avatar
Almost ready for my second attempt to install the original T5 behind a newer, one piece rear main seal engine. My first attempt lead to the clutch not disengaging, I believe because the pilot bushing was 0.005" larger than the crank hole. However, I'm looking at every piece of the system to try and reduce the chance of doing this again . Is there any difference in the crank hole depth between an older two-piece block and a later one-piece? I'm wondering if the front of the input shaft could be making contact with the crank.
Old Aug 1, 2022 | 07:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: T5 Input Shaft Interference?
[QUOTE=thainglo;6474356]Almost ready for my second attempt to install the original T5 behind a newer, one piece rear main seal engine. /QUOTE]
No issues with my T5 behind a 350HO Deluxe.
JamesC
Old Aug 1, 2022 | 09:28 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
My 85 Non-WC t-5 works just fine behind my one-piece rear main seal 350.
Water_Boy
Dec 5, 2014 07:17 PM
TennesseeIroc-Z
Apr 24, 2014 06:20 PM
rockstarr4
Dec 2, 2010 11:36 AM
RedHawkLB9
Mar 25, 2009 02:10 AM
