input shaft hole(for T-5) in (LB9)block?
Old Mar 22, 2009 | 12:11 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
hi guys...i was talking to the guys(bodyman/mechanics) at work...and he was saying that it might or might not have the the hole in the block for the input shaft(for T5).. is there anyway to find out if my car has that...it is a curent(89'-LB9-700) combo...they said i could find out by reading the vin?.. please help thx
Old Mar 22, 2009 | 12:38 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: input shaft hole(for T-5) in (LB9)block?
input shaft? do you mean in the crank shaft for the pilot bearing?
Old Mar 22, 2009 | 01:09 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
Yes!...im not that good in the mechanical department lol
Old Mar 23, 2009 | 09:47 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
i thought they all had a hole for the pilot bearing but im no exspert. maybe sombody else will correct me if im wrong or at least i hope so.
Old Mar 23, 2009 | 12:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If the car came with the 700R4 automatic (or any automatic for that matter) then no it will not have a pilot bearing or pilot bushing in the end of the crank. You will need to purchase one (pilot bearing is better since its roller bearings) and install it for use with a manual transmission.
Old Mar 23, 2009 | 03:41 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
so what would i have to replace?...the crank itself?
Old Mar 23, 2009 | 04:05 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
You should only need to buy the bearing/bushing and insert it into the end of the crankshaft. I had to do this when I dropped my 350 from an auto truck into my T-5 Camaro.
Kevin91Z, where can one go to get a roller pilot bearing? When I went to the local parts store I showed them the mangled one I pulled from the 305 and they had no idea they existed and sold me a pilot bushing that was listed in their parts book. It fit, but I figured the bearing would be better.
Old Mar 23, 2009 | 04:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have one from the dealership that I've never used.
JamesC
Old Mar 23, 2009 | 07:25 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
so all crank shafts have the hole for the pilot/roller bearing . is that right?
Old Mar 25, 2009 | 02:10 AM
Kevin91Z's Avatar
Yes, all crankshafts have the hole, but only manual trans cars will have the pilot bushing in the end of the crank. You dont need to change the crank, just install a bushing or a bearing in there. I think I got a bearing from our local parts store, Parts Plus.
C409
Sep 23, 2015 04:30 PM
transamgta87
Sep 1, 2015 07:07 PM
Cacike
Aug 27, 2015 05:10 PM
lakeffect2
Aug 23, 2015 08:44 AM
