T5 clutch pedal issue
Old Aug 5, 2022 | 08:36 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
This pedal problem is on a swapped car. It used to be a 700R4 but I doubt that's relevant. Is there supposed to be some sort of stop on the pedal and the safety switch? My pedal will go down to what feels like a hard stop, then if I give it a good push it will go farther and eventually stop at the floorboard. I have had a bunch of instances where the car does not start because the switch (plastic rod type) is out of adjustment. So I end up having to push the peal past that initial stop point until it makes contact. I quite often have to remove the fuse panel cover, reach up there and slide that plastic rod back to the beginning. Then it ratchets back down to where I think it should be. Only to go out of adjustment a few starts later, then the process repeats. Not sure if maybe I'm setup wrong or something like that.
Old Aug 7, 2022 | 04:46 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 clutch pedal issue
The early style you have was changed in the 80s. They weren't the most bulletproof design.
The later one acts like a stop of sorts. A metal flap presses the switch , which is attached to the pedal hanger on the left. They're not adjustable.
Old Aug 8, 2022 | 12:47 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I did the same swap earlier this year, I just bypassed the switch all together
This may not be the way you want to do things, but for my situation it works just fine lol.
Old Aug 11, 2022 | 10:33 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I did the same thing with my 700r4 to T5 conversion. I performed ZERO wiring additions for safety lockouts, etc. Works just fine for my situation.
Still need to connect my reverse lights- I've put that off since I have blackouts and they would be just more useful than useless anyway.
trafficlightguy
Sep 2, 2014 06:24 AM
Redroy@live.com
Jul 5, 2014 12:56 AM
Sonix
Jul 6, 2008 10:13 PM
jayk2k3
Jul 31, 2006 07:19 PM
sephiroth99
Jun 18, 2004 04:50 PM
