Stuck on reverse drum.
Old Sep 25, 2022 | 04:09 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Trying to finish up my rebuild but stuck on reverse drum. So my drum is in pretty bad shape but reverse always engaged nicely. Trying to reuse my drum, I purchased this kit which includes a wavy steel which is suppose to not eat into the drum. To my surprise this wavy plate(if you can even call it a plate) is so thin almost like sheet metal. I Was expecting a thicker steel to come with the kit to make up this lost clearance but all I got was the "wavy". But thinking about it now the wave is so thin might not even cushion the apply. Heard about the wavy being used in 82-86 700s, tore down 2 at a jy but they had the same bellville plate.. thinking about it now I'd probably be better off with a new drum or thicker reverse frictions? What's the solution here ? Looked up the alto drum saver but nobody sells it.
Old Sep 25, 2022 | 05:46 PM
vorteciroc's Avatar
Top Answer: 1
Re: Stuck on reverse drum.
Can you put a caliper on the Waved Steel, and tell us how thick it is?
Early Units did use a Waved Steel, with a Steel Apply Piston...
Later Units have an Aluminum Apply Piston with a Bellville Steel.
I personally like to use the Late Drum, Late Apply Plate, and the Early Waved Steel.
The Backing Plates are available in Selective thicknesses, for adjusting Clearance.
Old Sep 25, 2022 | 07:42 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Measures 0.03 or .030 right? My top plate measures 0.26 How much does the early wavy measure? The kit was suppose to come with a spacer plate, only got the wave.
Old Sep 26, 2022 | 09:13 PM
vorteciroc's Avatar
Top Answer: 1
0.0300" is too Thin.
The Original Waved Steel is more than double that Thickness.
If you want to take a chance...
You can purchase a second Waved Steel (another of what you have)...
Install 2 Waved Steels, directly on top of one another (the peaks and valleys of the Waved Steels MUST line-up with one another).
Old Sep 26, 2022 | 10:24 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Talked to the man Dana and he passed along some part numbers for the 82-86 wavy .080 steel and thicker frictions as well. The wavy I purchased from the bay was 30 dollars. 0.080 wave from Transtar, 10 bucks. Well see how it goes.
maroe624
Mar 29, 2019 09:27 PM
zoloft
Nov 2, 2007 11:32 AM
eagle_eyes
Brakes
Jul 26, 2005 10:51 AM
