Driveshaft Fitment Problems
Old Nov 28, 2022 | 10:51 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Specs; Stock '87 L98, swapped in a ~02 4L60e, stock 9 bolt, stock drive shaft
I recently swapped in 4l60e (from a truck) and as I am finishing up the small things went to install my stock driveshaft. All my research led me to believe that it should fit with no modifications needed. However with the car on jack stands and the rear suspension at full droop the stock shaft just barely fits. I had to give it a few bumps with my hand maybe 1/4" so it would fit. I can bolt the shaft in but am worried about at ride height the shaft bottoming out or causing damage. What's confusing to me is the slip yoke is not bottomed out in the transmission and looks to have room to slide further in.
Do the truck 4l60's have a shorter slip yoke or a shorter output shaft than F-body 700r4/4L660's?
Old Nov 29, 2022 | 10:02 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Driveshaft Fitment Problems
U have to have some slack for driveshaft movement or u will most certainly break something, seriously. U need to measure the correct length. U may be able to shorten your current shaft. Do it right the 1st time; a lot cheaper. Good luck.
Check youtube as to how to measure for a driveshaft
TTA976
Jun 14, 2014 04:55 PM
Bad-Newz
Mar 9, 2013 05:38 AM
Buck268
Jan 31, 2003 09:12 PM
Ghour_Demon
Mar 9, 2002 01:59 AM
super83Z
Mar 3, 2002 11:58 PM
