Gear Selector Cable Adjustment
Old Nov 29, 2022 | 11:14 AM
walkingdead5's Avatar
Car: 1991 Camaro Z-28
Looking to see if anyone is familiar with this particular gear selector cable design. I need to adjust it as it is off by "1 detent." I have seen this: http://shbox.com/trans/A4_trans_linkage.html (4th gen), but my deisgn (3rd gen) is different in that there is no tab to lift. This is off of a 1991 Camaro RS with 700R4. I have since moved to a 4L60E. Please see images below where one shows the offset and the other shows the gear selector cable at the "adjustment area" where there is a small (approx 1/8"D) circular opening at the bottom and top (as seen in the mirror). I certainly do not want to force or break anything (since it is a plastic housing), so would appreciate any instruction. Thank you!
Old Nov 29, 2022 | 02:38 PM
vorteciroc's Avatar
Top Answer: 1
re: Gear Selector Cable Adjustment
Is the Gear-Selector Cable that you are using original to the Car/ the THM700-R4...
Or the 4L60E?
The Linkage Arms on each Transmission are slightly different...
It is best to match the Gear-Selector Cable to the Transmission being used...
If not, try swapping the Linkage Arms.
Old Nov 29, 2022 | 02:41 PM
The gear selector cable is the original (700R4). The 4L60E trans did not come with a bracket or linkage arm, so I had to get creative sifting thru a junkyard. Anyhow, any idea how to adjust this stock 700R4 cable? The plastic housing (in the "adjustment area") just seems slightly different than the "norm!" Thx!
I also noticed that http://shbox.com/trans/A4_trans_linkage.html is for a 4th gen...do you or anyone know the adjustment method for the 3rd gen gear selector cable?
Old Nov 30, 2022 | 01:19 PM
Re: Gear Selector Cable Adjustment
**BUMP**! for sure someone can tell me if & how the 3rd gen gear selector cable can be adjusted as it's 4th gen successor!
Old Nov 30, 2022 | 03:12 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
maybe you can use a different bracket on the tranny - like the top one below for a B&M Megashifter. it has multiple holes so maybe one would fit with what you're doing?
these brackets are B&M part number 35498
Old Nov 30, 2022 | 03:18 PM
Actually found a decent deal for that kit here:
Amazon Amazon
Old Dec 1, 2022 | 09:33 AM
@vorteciroc So I ordered that B&M bracket, but just curious if there is anyway to adjust a 3rd gen gear selector cable or did that option not come out until the 4th gen?
Old Dec 1, 2022 | 03:43 PM
vorteciroc's Avatar
Top Answer: 1
Not that i recall.
Old Dec 2, 2022 | 07:26 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
IIRC the linkage arm on the transmission should be slotted to allow for adjustment where the cable installs to it. the pic above shows no slot.
at least for the handful that I've taken apart and put back together.
Old Dec 2, 2022 | 08:46 AM
unfortunately, my 4L60E did not come with that linkage, so I had to grab one from a junkyard. The B&M one pictured above should arrive today, and hopefully those slots will accommodate. Thank you.
Old Dec 4, 2022 | 11:13 AM
Thx all!
@battmann used your recommendation
Old Dec 4, 2022 | 10:44 PM
battmann's Avatar
Hell yeah! 👍🏻
mark87Z28
Dec 2, 2008 10:37 AM
stiers
Jun 23, 2002 08:01 PM
