need fast reply $100 5 speed
found a 86 bird in {parts} yard it has a stick shift i asume that
it is a 5 speed right can get it for a 100 bucks worth it
going in a 90 rs any problems that u might now of
need fast reply it will be gone soon
thanks for the help
rob
thanks for the help
rob
I got one from the boneyard for $96. It looks like it's in good condition but i'm probably gonna rebuild it anyway. I'm not gonna take any chances on an 18 year old tranny.
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Robert C, it probably needs a rebuild-which can some times be expensive. Price out how much a rebuild would cost and compare it to the price of a new one. Go from there. Good Luck
Sometimes the parts on a rebuild for a manual tranny are so expensive they a rebuilder would get a junkyard tranny to swap good parts into it .. at least thats what my instructor told me friday night buti got one from a boneyard and its been doing goood for the past 6 months
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Just make sure it's coming from the same engine as you need it for. A V6 trans won't easily work with a V8 engine and vice-versa.
Pete
Pete
thanks everyone i got the whole setup pedels trans,bell
stick,slave cil and hardware for a 160 bucks it came out of
a lg4 86 bird going in my 90 rs lo3 i need to know if the speedo
will just hook up and what is the other conector on the 5 sp
The other connector is the reverse light switch.
Your car should have an electronic VSS but the 86 Bird might still have a Cable operated VSS. Pull the VSS out of the trans and see if it has a plastic gear on it.....that's a cable VSS. The electronic one *should* have some type of reluctor wheel with a magnetic pickup.(never seen one out)
BTW, I'm having the same VSS problem as you. I got a T5 from an 84 Bird.
Car: '89 GTA
Engine: 427 BBC
Transmission: TH-350
Rob where abouts in Ft Lauderdale, I'm out west near Weston, The Manual swap is fun did it to my GTA, (6 speed) if you have any Questions. Im always full of Answers
the t5 has a little gear drive but no cable just some elc. wires
can i just change connectors they are diffrent and let it ride
and i asume that i can do that to my reverse light. from the auto shifter
hey 89gta i used to do tile and marble out there couple
of years ago i live st rd 84 ,i95 we"ll have to get together
some time
some time
Fast355
Dec 2, 2016 06:33 PM
